Charmed Kafka How-To | Configuration backup and restore
Charmed Kafka’s configuration is distributed using Charmed ZooKeeper. A Charmed ZooKeeper backup can be stored on any S3-compatible storage. S3 access and configurations are managed with the s3-integrator charm.
This guide contains step-by-step instructions on how to deploy and configure the s3-integrator charm for AWS S3, send the configurations to the Charmed ZooKeeper application, and finally manage your Charmed ZooKeeper backups.
Configure s3-integrator
First, deploy the s3-integrator charm:
juju deploy s3-integrator
juju run s3-integrator/leader sync-s3-credentials access-key=<aws-access-key-id> secret-key=<aws-secret-key>
Then, use juju config to add your configuration parameters. For example:
juju config s3-integrator \
    endpoint="https://s3.us-west-2.amazonaws.com" \
    bucket="zk-backups-bucket-1" \
    path="/zk-backups" \
    region="us-west-2"
The only mandatory configuration parameter in the command above is the bucket.
Integrate with Charmed ZooKeeper
To pass these configurations to Charmed ZooKeeper, integrate the two applications:
juju integrate s3-integrator zookeeper
You can create, list, and restore backups now:
juju run zookeeper/leader create-backup
juju run zookeeper/leader list-backups
juju run zookeeper/leader restore backup-id=<backup-id-here>
Create a backup
Check that Charmed ZooKeeper deployment with configurations set for S3 storage is active and idle with the juju status command. Once it’s active, create a backup with the create-backup command:
Charmed ZooKeeper backups created with the command above will always be full backups: a copy of all the Charmed Kafka configuration will be stored in S3.
The command will output the ID of the newly created backup:
                                     Backup created
┃ Id                   ┃ Log-sequence-number ┃ Path                           ┃
│ 2024-09-12T14:32:46Z │          8589934621 │ zookeeper_backups/2024-09-12T1 │
│                      │                     │ 4:32:46Z/snapshot              │
List backups
To list available backups, run the list-backups command:
This command shows available backups, for example:
                                     Backups
│ 2024-09-12T14:32:00Z │          8589934621 │ zookeeper_backups/2024-09-12T1 │
│                      │                     │ 4:32:00Z/snapshot              │
│ 2024-09-12T14:26:12Z │          8589934621 │ zookeeper_backups/2024-09-12T1 │
│                      │                     │ 4:26:12Z/snapshot              │
Below is a list of parameters shown for each backup:
  • Id: identifier of the backup.
  • Log-Sequence-number: a database-specific number to identify its state. Learn more about the Zxid on Apache ZooKeeper documentation.
  • Path: path of the snapshot file in the S3 repository.
Restore a backup
This operation puts you at risk of losing unsaved configuration data. We recommend creating a backup first.
To restore from backup, run the restore command and pass the backup-id (in the YYYY-MM-DDTHH:MM:SSZ format) that is listed in the list-backups action output:
The restore will then proceed. Follow its progress using juju status.
