`charmcraft upload`
Usage:
charmcraft upload [options] <filepath>
Summary:
Upload a charm or bundle to Charmhub.
Push a charm or bundle to Charmhub where it will be verified. This command will finish successfully once the package is approved by Charmhub.
In the event of a failure in the verification process, charmcraft will report details of the failure, otherwise it will give you the new charm or bundle revision.
Upload will take you through login if needed.
Options:
-h, --help Show this help message and exit
-v, --verbose Show debug information and be more verbose
-q, --quiet Only show warnings and errors, not progress
--verbosity Set the verbosity level to ‘quiet’, ‘brief’, ‘verbose’, ‘debug’ or ‘trace’
-p, --project-dir Specify the project’s directory (defaults to current)
--format Produce the result formatted as a JSON string
--release The channel(s) to release to (this option can be indicated multiple times)
--name Name of the charm or bundle on Charmhub to upload to
--resource The resource(s) to attach to the release, in the : format (this option can be indicated multiple times)
See also:
  • close
  • create-lib
  • fetch-lib
  • list-lib
  • login
  • logout
  • names
  • publish-lib
  • register
  • register-bundle
  • release
  • resource-revisions
  • resources
  • revisions
  • status
  • upload-resource
  • whoami
