`charmcraft release`
Usage:
charmcraft release [options] <name>
Summary:
Release a charm or bundle revision in the channel(s) provided.
Charm or bundle revisions are not published for anybody else until you release them in a channel. When you release a revision into a channel, users who deploy the charm or bundle from that channel will get see the new revision as a potential update.
A channel is made up of track/risk/branch with both the track and the branch as optional items, so formally:
[track/]risk[/branch]
Channel risk must be one of stable, candidate, beta or edge. The track defaults to latest and branch has no default.
It is enough just to provide a channel risk, like stable because the track will be assumed to be latest and branch is not required.
Some channel examples:
stable
edge
2.0/candidate
beta/hotfix-23425
1.3/beta/feature-foo
When releasing a charm, one or more resources can be attached to that release, using the --resource option, indicating in each case the resource name and specific revision. For example, to include the resource thedb revision 4 in the charm release, do:
charmcraft release mycharm --revision=14 \
    --channel=beta --resource=thedb:4
Releasing a revision will take you through login if needed.
Options:
-h, --help Show this help message and exit
-v, --verbose Show debug information and be more verbose
-q, --quiet Only show warnings and errors, not progress
--verbosity Set the verbosity level to ‘quiet’, ‘brief’, ‘verbose’, ‘debug’ or ‘trace’
-p, --project-dir Specify the project’s directory (defaults to current)
-r, --revision The revision to release
-c, --channel The channel(s) to release to (this option can be indicated multiple times)
--resource The resource(s) to attach to the release, in the : format (this option can be indicated multiple times)
See also:
  • close
  • create-lib
  • fetch-lib
  • list-lib
  • login
  • logout
  • names
  • publish-lib
  • register
  • register-bundle
  • resource-revisions
  • resources
  • revisions
  • status
  • upload
  • upload-resource
  • whoami
