Usage:
charmcraft pack [options]
Summary:
Build and pack a charm operator package or a bundle.
You can juju deploy
the resulting .charm
or bundle’s .zip
file directly, or upload it to Charmhub with charmcraft upload
For the charm you must be inside a charm directory with a valid metadata.yaml
, requirements.txt
including the ops
package for the Python operator framework, and an operator entrypoint, usually src/charm.py
. See charmcraft init
to create a template charm directory structure.
For the bundle you must already have a bundle.yaml
(can be generated by Juju) and a README.md file.
Options:
-h, --help |
Show this help message and exit |
-v, --verbose |
Show debug information and be more verbose |
-q, --quiet |
Only show warnings and errors, not progress |
--verbosity |
Set the verbosity level to ‘quiet’, ‘brief’, ‘verbose’, ‘debug’ or ‘trace’ |
-p, --project-dir |
Specify the project’s directory (defaults to current) |
--format |
Produce the result in the specified format (currently only ‘json’) |
--debug |
Launch shell in build environment upon failure |
--destructive-mode |
Pack charm using current host which may result in breaking changes to system configuration |
--shell |
Launch shell in build environment in lieu of packing |
--shell-after |
Launch shell in build environment after packing |
--bases-index |
Index of ‘bases’ configuration to build (can be used multiple times); zero-based, defaults to all |
--force |
Force packing even after finding lint errors |
--measure |
Dump measurements to the specified file |
--include-all-charms |
For bundles, pack all charms whose source is inside the bundle directory |
--include-charm |
For bundles, pack the charm in the referenced path. Can be used multiple times |
--output-bundle |
Write the bundle configuration to this path |
See also:
analyze
clean
init
version
