Charmcraft > List of Charmcraft commands
You can get a list of all the Charmcraft commands by invoking charmcraft help --all
in a terminal.
To drill down into each command use charmcraft help <command name>
This same information is also provided below. Click on a command to view information on it.
analyse | Analyze a charm |
clean | Purge project artifacts |
close | Close a channel for a charm or bundle |
create-lib | Create a charm library |
fetch-lib | Fetch one or more charm libraries |
init | Initialize a charm operator package tree and files |
list-lib | List all libraries from a charm |
login | Login to Charmhub |
logout | Logout from Charmhub and remove token |
names | List your registered charm and bundle names in Charmhub |
pack | Build the charm or bundle |
publish-lib | Publish one or more charm libraries |
register | Register a charm name in Charmhub |
register-bundle | Register a bundle name in Charmhub |
release | Release a charm or bundle revision in one or more channels |
remote-build | Build a charm remotely on Launchpad. |
resource-revisions | List revisions for a resource associated to a charm in Charmhub |
resources | List the resources associated with a given charm in Charmhub |
revisions | List revisions for a charm or a bundle in Charmhub |
status | Show channel and released revisions |
upload-resource | Upload a resource to Charmhub |
upload | Upload a charm or bundle to Charmhub |
version | Show charmcraft version |
set-resource-architectures | Set the architectures for a resource revision in Charmhub |
whoami | Show your Charmhub login status |
