This appendix shows one way to install a rudimentary Ceph cluster with Juju backed by an AWS cloud. See Ceph documentation to find out more about Ceph.
Below, we install three Ceph monitors and three OSD systems. Each OSD system has two 32 GiB OSDs and one 8 GiB volume dedicated to the OSD journal. All volumes are EBS-based and magnetic (i.e. not SSD).
juju deploy -n 3 ceph-mon
juju deploy -n 3 ceph-osd --storage osd-devices=ebs,32G,2 --storage osd-journals=ebs,8G,1
juju add-relation ceph-mon ceph-osd
This will take a while. Presented below is the final output to the juju status
command for a model called ‘ceph’:
Model Controller Cloud/Region Version SLA
ceph aws aws/us-east-1 2.3.1 unsupported
ceph-mon 10.2.9 active 3 ceph-mon jujucharms 18 ubuntu
ceph-osd 10.2.9 active 3 ceph-osd jujucharms 252 ubuntu
ceph-mon/0 active idle 0 54.157.253.136 Unit is ready and clustered
ceph-mon/1* active idle 1 54.166.249.23 Unit is ready and clustered
ceph-mon/2 active idle 2 54.221.92.67 Unit is ready and clustered
ceph-osd/0 active idle 3 54.156.62.76 Unit is ready (2 OSD)
ceph-osd/1 active idle 4 54.167.125.232 Unit is ready (2 OSD)
ceph-osd/2* active idle 5 54.159.206.197 Unit is ready (2 OSD)
0 started 54.157.253.136 i-02969e42b6654c4cb xenial us-east-1c running
1 started 54.166.249.23 i-09a55570b2c47159f xenial us-east-1a running
2 started 54.221.92.67 i-04467e3dce94a0795 xenial us-east-1d running
3 started 54.156.62.76 i-0ee866a3b9a8f2b02 xenial us-east-1a running
4 started 54.167.125.232 i-0610ebe802907fc3e xenial us-east-1d running
5 started 54.159.206.197 i-0b9fbb073810df44c xenial us-east-1c running
ceph-mon:mon ceph-mon:mon ceph peer
ceph-mon:osd ceph-osd:mon ceph-osd regular
Now view the status of the cluster from Ceph itself by running the ceph status
command on one of the monitors:
juju ssh ceph-mon/0 sudo ceph status
Sample output:
cluster 316b16da-f02a-11e7-9315-22000b270782
health HEALTH_OK
monmap e2: 3 mons at {ip-10-111-155-227=10.111.155.227:6789/0,ip-10-153-224-190=10.153.224.190:6789/0,ip-10-232-134-102=10.232.134.102:6789/0}
election epoch 12, quorum 0,1,2 ip-10-111-155-227,ip-10-153-224-190,ip-10-232-134-102
osdmap e27: 6 osds: 6 up, 6 in
flags sortbitwise,require_jewel_osds
pgmap v62: 64 pgs, 1 pools, 0 bytes data, 0 objects
202 MB used, 191 GB / 191 GB avail
64 active+clean
This tells us that there are six OSDs, 191 GiB of available space, and all Placement Groups are ‘active+clean’.
Now list the storage from Juju:
juju list-storage
Output:
[Storage]
Unit Id Type Pool Provider id Size Status Message
ceph-osd/0 osd-devices/0 block ebs vol-078db09cf280baa61 32GiB attached
ceph-osd/0 osd-devices/1 block ebs vol-04ef7df7ae5ef688b 32GiB attached
ceph-osd/0 osd-journals/2 block ebs vol-056e0f1ae9ef3ee35 8.0GiB attached
ceph-osd/1 osd-devices/3 block ebs vol-06a0a30d8bb069be5 32GiB attached
ceph-osd/1 osd-devices/4 block ebs vol-021706e37f90eb5c1 32GiB attached
ceph-osd/1 osd-journals/5 block ebs vol-02bfd75cae548800c 8.0GiB attached
ceph-osd/2 osd-devices/6 block ebs vol-0321404bf7050c1b3 32GiB attached
ceph-osd/2 osd-devices/7 block ebs vol-0cfc7464af10aebd2 32GiB attached
ceph-osd/2 osd-journals/8 block ebs vol-0236aed9919b0ec8e 8.0GiB attached
Here we see each Ceph OSD unit has two OSD volumes and one journal volume, for a total of nine volumes.
This Ceph cluster is used as a basis for some examples provided in Using Juju Storage.
