Once you have deployed Kubeflow, it is time to access the Kubeflow dashboard.
1. Get authentication credentials
To display your access credentials, run the following commands:
juju config dex-auth static-username
juju config dex-auth static-password
By default, these are both empty. If you wish to set them (which is necessary to enable simple authentication), add the relevant string to the end of the command, e.g.
juju config dex-auth static-username=admin
juju config dex-auth static-password=AxWiJjk2!hu4fFga7
2. Find the IP address of the Kubeflow dashboard
To find the IP address of the Kubeflow dashboard for your deployment run:
kubectl get services -n kubeflow
where kubeflow
is the name you gave to your Juju model, and hence the namespace of your Kubeflow deployment.
3. Access the dashboard
For local Kubeflow deployments, such as in a workstation, you can simply access the link found in the previous step, appending xip.io
, for example: http://10.64.140.43.xip.io
However, for remote deployments, or running on a virtual machine, creating a SOCKS proxy is required to access the dashboard. This can be done as follows:
Logout from the current session with the
exit
command -
Re-establish connection to the machine using
ssh
with SOCKS proxy enabled through the-D 9999
parameter. As in the example below:ssh -D 9999 ubuntu@<machine_public_ip>
On your computer, go to
Settings > Network > Network Proxy
, and enable SOCKS proxy pointing to:127.0.0.1:9999
On a new browser window, access the link given in the previous step, appended by
.xip.io
, for example:http://10.64.140.43.xip.io
