Cloud (substrate)
See also: How to manage a cloud
To Juju, a cloud (or backing cloud) is any entity that has an API that can provide compute, networking, and optionally storage resources in order for application units to be deployed on them. This includes public clouds such as Amazon Web Services, Google Compute Engine, Microsoft Azure and Kubernetes as well as private OpenStack-based clouds. Juju can also make use of environments which are not clouds per se, but which Juju can nonetheless treat as a cloud. MAAS and LXD fit into this last category. Because of this, in Juju a cloud is sometimes also called, more generally, a substrate.
Contents:
Supported clouds
See: List of supported clouds
Cloud differences
While Juju aims to make all clouds feel the same, some differences still persist depending on whether the cloud is a machine cloud or a Kubernetes cloud or a specific cloud as opposed to another.
Machine clouds vs. Kubernetes clouds
Juju makes a fundamental distinction between ‘machine’ clouds – that is, clouds based on bare metal machines (BMs; e.g., MAAS), virtual machines (VMs; e.g., AWS EC2), or system containers (e.g., LXD) – and ‘Kubernetes’ clouds – that is, based on containers (e.g., AWS EKS).
See more: Machine
While the user experience is still mostly the same – bootstrap a Juju controller into the cloud, add a model, deploy charms, scale, upgrade, etc. – this difference affects the required system requirements (e.g., for a Juju controller, 4GB vs. 6GB memory), the way you connect the cloud to Juju (add-cloud + add-credentials vs. add-k8s), what charms you can deploy (‘machine’ charms vs. ‘Kubernetes’ charms), and – occasionally – what operations you may perform and/or how (e.g., enable-ha is currently supported just for machine controllers; scaling an application is done via add-unit on machines and via scale-application on K8s).
See more: Tutorial, Juju How-to guides
Juju’s vision is to eventually make this distinction irrelevant.
Cloud foo vs. cloud bar
As a Juju user you will sometimes also notice small differences tied to a cloud’s specific identity, beyond the machine-Kubernetes divide.
This usually affects the setup phase (the information you have to supply to Juju to connect Juju to your cloud, and whether Juju can retrieve any of that automatically for you) and, later on, the customisations you can make to your deployment (e.g., small differences in configurations, constraints, placement directives, subnets, spaces, storage, etc., depending on the features available / supported for a given cloud).
See more: List of supported clouds > <cloud name>
Cloud definition
In Juju, cloud definitions can be provided either interactively or via a YAML file or (depending on the cloud) environment variables.
Regardless of the method, they are saved in a file called public-clouds.yaml (for public clouds; on Linux, typically: ~/.local/share/juju/public-clouds.yaml) or clouds.yaml (for user-defined clouds, including Kubernetes; on Linux, the default location is: ~/.local/share/juju/clouds.yaml).
These files both follow the same basic schema.
Expand to view an example 'clouds.yaml' file with a definition for LXD and Amazon EKS
clouds:
  lxd:
    type: lxd
    auth-types:
      - certificate
    endpoint: <endpoint>
    regions:
      default:
    config:
      apt-http-proxy: <endpoint>
  eks:
    type: kubernetes
    host-cloud-region: ec2/eu-north-1
    auth-types:
      - userpass
      - oauth2
      - clientcertificate
    regions:
      eu-north-1:
    config:
      operator-storage: gp2
      workload-storage: gp2
    ca-certificates: <certificates>
The rest of this section gives details about this schema.
Source
tl;dr:
The most important keys are clouds, .<cloud name>, ..type, ..auth-types, and ..endpoint.
clouds
Status: Required.
Purpose: To define different clouds.
Value: Mapping. Keys are cloud names.
clouds.<cloud>
Status: Required.
Purpose: To define a cloud.
Name: String = the name of the cloud. For built-in clouds and for public clouds, set by Juju; see List of supported clouds > <cloud name>. For user-defined clouds, set by the user.
Value: Mapping. Keys are strings = cloud properties.
clouds.<cloud>.auth-types
Status: Required.
Purpose: To define the authentication types supported by the clouds.
Value: Sequence. Items are strings = authentication types supported by the cloud given its cloud type. See more: List of supported clouds > <cloud name> > Cloud definition.
clouds.<cloud>.ca-certificates
Status: Optional.
Purpose: To define the Certificate Authority certificates to be used to validate certificates of cloud infrastructure components.
Value: Sequence. Items are strings = base64-encoded x.509 certs.
clouds.<cloud>.config
Status: Optional.
Purpose: To define a model configuration to use when bootstrapping Juju in the cloud. The configuration will be combined with Juju-generated, and user-supplied values; user-supplied values take precedence.
Value: Mapping. Keys are model configuration keys (either generic or cloud-specific). See more: List of model configuration keys and/or List of supported clouds > <cloud>.
clouds.<cloud>.description
Status: Optional.
Purpose: To describe the cloud.
Value: String = the cloud description.
clouds.<cloud>.endpoint
Status: [TO BE ADDED]
Purpose: To define the default endpoint for the cloud regions. Note: It may be overridden by a region.
Value: String = the endpoint URL or, for manual clouds, the SSH URI (e.g., ubuntu@1.2.3.4).
clouds.<cloud>.host-cloud-region
Purpose: To define the Kubernetes host cloud region.
Value: String = the Kubernetes host cloud region, in the following format: <cloudType>/<region>.
clouds.<cloud>.identity-endpoint
Purpose: To define the default identity endpoint for the cloud regions. Note: It may be overridden by a region.
Value: String = the default identity endpoint for the cloud regions.
clouds.<cloud>.region-config
Status: Optional.
Purpose: To define a cloud-specific configuration to use when bootstrapping Juju in a specific cloud region. The configuration will be combined with Juju-generated and user supplied values; user supplied values take precedence.
Value: [TO BE ADDED]
clouds.<cloud>.regions
Status: Optional.
Purpose: To define the regions available in the cloud.
Value: Mapping. Keys are strings = region names. Cloud-specific. See more: List of supported clouds > <cloud>.
clouds.<cloud>.regions.<region>
Value: String = the name of the region.
clouds.<cloud>.regions.<region>.endpoint
Value: String = the region’s primary endpoint URL.
clouds.<cloud>.regions.<region>.identity-endpoint
The region’s identity endpoint URL. If the cloud/region does not have an identity-specific endpoint URL, this will be empty.
clouds.<cloud>.regions.<region>.storage-endpoint
The region’s storage endpoint URL. If the cloud/region does not have an storage-specific endpoint URL, this will be empty.
clouds.<cloud>.storage-endpoint
Status: Optional.
Purpose: To define the default storage endpoint for the cloud regions. Note: It may be overridden by a region.
Value: String = the storage endpoint.
clouds.<cloud>.type
Status: Required.
Purpose: To define the type of cloud in Juju.
Value: String = the cloud type. See more: List of supported clouds > <cloud>.
